fat boy s
Old Mar 2, 2017 | 09:56 AM
Edmon's Avatar
Edmon
Stage IV
Default fat boy s
hello , I'm new in motorcycle world, I have a footboy s 2016 and just bought some s&s slip on, can I use any slip on that fit? I put them on and its popping some times is this normal?
Old Mar 2, 2017 | 10:34 AM
durtyburt's Avatar
durtyburt
My 2016 Slim S has Cobra slip-ons,dealer told me didn't need a tuner unless going w/full system.There's a little popping but nothing that bad, it is normal.I suppose you could go with a tuner which would help but I'm no expert,do a search on here probably get your answer.
Old Mar 2, 2017 | 10:36 AM
aaron___92's Avatar
aaron___92
Welcome. You can get rid of them with a tuner. FP3 is convenient and perfect if you don't plan on doing any other engine upgrades.
Old Mar 2, 2017 | 11:59 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Did you use any type of exhaust sealer on the small ends of the slip-ons before your installation? The popping you hear is most likely related to a leak at the joint between the header pipe and the slip-ons.
Old Mar 2, 2017 | 01:16 PM
Edmon's Avatar
Edmon
Stage IV
Thanks for all the coments i want to get an exhaust eventually, so i will neet a tuner, ill check for leaks thanks .
Old Mar 3, 2017 | 07:37 AM
Freak Show's Avatar
Freak Show
i love the footboy
Old Mar 5, 2017 | 07:08 PM
Fatboy16S's Avatar
Fatboy16S
Excellent choice on your bike! I love mine! I went with the tts tuner, a set of reinhart crossbacks, and a full dyno tune. I did get a lot of popping when just a map was loaded in, but after the tune, almost none. Only problem is getting my sena 10 s loud enough to hear over the exhaust. I was going to leave it stock, but after hitting a dear on my way to work last year in the early morning, I thought louder might keep that from happening again? Totaled the front end.
FatKen
Jul 26, 2016 06:25 AM
kurt84
Exhaust System Topics
Nov 4, 2015 09:42 AM
stl jeanes
Sep 2, 2012 10:16 AM
SFCTRIP
Aug 18, 2009 07:10 AM
fatboy44
Oct 29, 2006 10:24 PM
