Yes it will bolt up. No it won't work correctly due to oxygen sensors. Actually lack there of. 2005 didn't have them but the frame is the same.
This is for a full exhaust. If looking at just slip-on Muffler's then that's a different story as the cross over tube is completely different. They changed the cross over tube in 2007 to be part of the head pipe and not connect to the muffler.
So so if you want an earlier exhaust it must be 100% complete and to work correctly in your 2011 it must have the proper oxygen sensor bungs installed (12 mm if memory serves me correct. I don't know the year they changed from 18 to 12mm bungs)
