Jetting/tuning problem
The kit consist of boring out the stk jugs to accept bigger pistons obviously, cnc porting the heads with bigger valves/springs, 577 chain drive cam which I have already converted to the newer style hydraulic setup with feuling billet plate/billet larger oil pump, zippers ignition module that was already set up to run for this kit and the S&S G1 which means they block of the "air bleed" and install a 3rd jet which is suppose to pick up the flat spot at about 3k-4K ish rpm's. The parameters call for a .032-.036 on the intermediate jet and a .078-.088 on the main. Now I have tried multiple combinations and just messed with the intermediate jet to be able to ride it but it won't get off its face. When I accelerate easy and I mean easy it just spits, sputters, surges etc etc. I have followed all the steps stated by Zippers and S&S. I have checked for vacuum leaks and now I'm just at a stand still. I plan on getting it dyno tuned but have to put some miles on it before then. Before anyone says "S&S is either a closed or wide open carb", I had one already on the stk motor and it ran great for 11yrs now. Any suggestions?
