need help
Old Apr 22, 2018 | 06:03 PM
ricturner's Avatar
ricturner
1st Gear
Default need help
I have a 2003 Fatboy with fuel injection that I have upgraded to the Screaming Eagle cam plate (25284-11) S&S lifters (33-5350) and Screaming Eagle roller rockers (17378-98). I needed to replace the old style chain tensioners and got a deal on all the parts (I thought). I took everything apart and reassembled it as manual and install instructions and when I start it the front cylinder has no compression and won't fire. I have disassembled it twice now and can't find anything wrong. I can get compression when trying to partial assemble but when I put everything together same problem. Anyone have an idea what I am missing before I have a HD mechanic look at it?
Old Apr 22, 2018 | 09:40 PM
nvbirdman's Avatar
nvbirdman
Sounds like you have a compression release and it is activated for some reason.
Old Apr 22, 2018 | 09:52 PM
langwilliams's Avatar
langwilliams
push rod too long an not allowing a valve to close?
Old Apr 22, 2018 | 09:56 PM
Dave0176's Avatar
Dave0176
You didn't mention anything about pushrods, are they stock or adjustable. Also remember the stock pushrods the exhaust is longer, so if you skewed them the intake valve will stay slightly open.
Old Apr 22, 2018 | 10:29 PM
TomCop's Avatar
TomCop
When you change the lifters to an other brand you need adjustable pushrods.
For each cylinder you need to put the piston on TDC and check if you can still turn the pushrods with your thumb and index finger.
In your case the pushrod will probably not rotate, meaning your valve is still slightly open.
It's an easy fix, just get it done right.
Old Apr 22, 2018 | 10:40 PM
ricturner's Avatar
ricturner
1st Gear
They are the stock push rods. They work in the rear cylinder. It will fire. I can rotate the push rod. They are tight but will rotate with my fingers.
TSD
Jun 10, 2013 01:38 PM
atrain68
Dec 22, 2009 04:48 PM
NorthGeorgiaHawg
EVO
Nov 29, 2009 09:04 PM
flhtupser
Exhaust System Topics
Mar 23, 2009 03:58 PM
CndUltra95
Jan 14, 2009 09:22 AM
