Kickstand kaddy
Old Jul 4, 2018 | 11:27 PM
balloo's Avatar
balloo
Default Kickstand kaddy
I just found out about this, and seems like a good idea.
Kickstand Kaddy.com
Contacted him by phone, and he makes them for Softail as well as touring models.
Anybody using one? What are your thoughts.
Thanks
Old Jul 4, 2018 | 11:49 PM
Campy Roadie's Avatar
Campy Roadie
My thought is it isn't needed.
Old Jul 5, 2018 | 06:29 AM
Bluraven's Avatar
Bluraven
I've never heard of a jiffy stand spring failing on any bike.
I supposed it could happen but so could a 1000 other things.
Old Jul 5, 2018 | 07:26 AM
Campy Roadie
I've knocked them off/bent doing cone course work; I keep a spare spring with the cones and tape measure. Easy to change on a Touring model, just put the bike on the right side engine/bag guards and swap it out. Not as easy on the Dyna Defenders, you have to put washers in the spring to make it longer for install.
Old Jul 5, 2018 | 07:56 AM
heybaylor's Avatar
heybaylor
no washers needed, just loosen/pull the pivot bolt, remove/lift up locking plate, swing it forward, attach spring put bolt in loose, swing it back too get locking plate in position.
tighten nut
Old Jul 5, 2018 | 12:39 PM
Campy Roadie
tighten nut
You're mistaken, on a Dyna you need washers. There isn't a pivot bolt, just a bolt that threads into the jiffy stand itself to keep it in the pivot block under the frame. It doesn't go forward like a Touring model. I've changed way too many of them out in the hot sun. I may have forgotten some things in my old age but this ain't one of them
As I said, it's easy on a Touring bike.
Old Jul 5, 2018 | 01:56 PM
hattitude's Avatar
hattitude
Seems like a solution in search of a problem.....
Just replace the spring if it gets loose/worn and your jiffy stand starts to bounce.
If you are a hardcore foot board grinder... competition based or otherwise, keep a spare spring in your bag....
I just don't see the need for 99% of HD riders....
Old Jul 5, 2018 | 02:26 PM
squirrelsnest's Avatar
squirrelsnest
I mounted one on each side of the bike!
Ventana
May 10, 2021 01:38 PM
risuperglidecustomman
May 15, 2013 03:42 AM
PinkBikerChic
Feb 18, 2011 11:06 AM
Arizona
Sep 11, 2008 02:08 AM
Denbo
Oct 26, 2006 01:47 PM
