114” Fatboy numbers
Old Jul 12, 2018 | 02:16 PM
AV8BDriver's Avatar
AV8BDriver
6th Gear
Default 114” Fatboy numbers
First post here other than my introduction post.
Well I got my first Harley for Father’s Day and decided to upgrade to stage two. It is a 114” with Vance and Hines 2 into 2 pipes, the stock high flow 114 AF, torque cam and Harley tuner. I don’t really know much about Harley’s or what the numbers should look like. There aren’t many dyno sheet posted so I am posting mine here. My first thought was the numbers look low. My other bike is a 2018 KTM SuperDuke R so looking at the numbers are not exactly apples to apples.
Here is my dyno sheet. Is this good or bad? It feels stronger than it did before I had the work done. I read somewhere that the 114” had 114 lbft of torque stock. If that is truely the case, I didn’t gain much at all. Let me know your thoughts.
File Type: pdf
Old Jul 12, 2018 | 05:12 PM
reynoldss's Avatar
reynoldss
A Woods 22x and a power vision tuner 111-115 hp 126-130 torque with the 114.
Old Jul 12, 2018 | 05:58 PM
FatBob2018's Avatar
FatBob2018
It's okay. Maybe a little low on torque, but that's probably due to the 2-into-2.
That's the difference between crankshaft torque (which is what Harley quotes) and rear wheel torque (which is what the dyno measured). Crankshaft torque is claimed to be 118, but in reality by the time it gets on the dyno a 114 generally delivers about 100 ft/lbs. So your Stage II boosted that to about 117 ft/lbs, a decent jump.
I would strongly suggest running some SmartTune sessions though. Currently you're probably running the stock tune, and that's designed for an entirely different exhaust, so the tune is almost certainly not optimal for your configuration. The SmartTune should help it dial in better.
JimGnitecki
Engine Mechanical Topics
172
Feb 5, 2015 02:31 PM
MikeZ
Dec 7, 2011 04:50 AM
sick_dyna
Aug 14, 2008 06:11 AM
kawsakimx6
Feb 17, 2008 05:18 PM
Stumpman
Aug 9, 2006 12:03 AM
