Engine gusset? Cracked case?
Old Aug 12, 2018 | 02:16 PM
2003flstfi's Avatar
2003flstfi
Default Engine gusset? Cracked case?
Doing a little polishing after a ride I discovered this crack. Not able to find any information in the service manual thought maybe somebody here had some thoughts on the issue. Any input would be appreciated
Old Aug 12, 2018 | 02:26 PM
Bubby's Avatar
Bubby
Can you get a picture directly in front of that?
Old Aug 12, 2018 | 02:33 PM
2003flstfi's Avatar
2003flstfi
About as good as I can get. 2003 Softail by the way
Old Aug 12, 2018 | 04:45 PM
Pitbull_Dallas's Avatar
Pitbull_Dallas
If you're talking about that rectangular hole, it's made that way. My 07 has the exact same feature on the block/casing below the rear cylinder. And that bright line/step in the case is a mismatch in the manufacturing casting mold. Mine has it too. They machine the casing, leaving the bright line. On yours it looks like they didn't quite finish the machining and left a whisker up near the cylinder. If you look close at the whisker you'll see why they machine it.
Image..
https://images.search.yahoo.com/imag...arch.yahoo.com
Old Aug 12, 2018 | 06:17 PM
Shawry's Avatar
Shawry
That is fine. The rectangular hole is there to put a lever in to help when splitting the cases.
There were some issues in later model bikes where due to the case sealant not being applied properly, oil would weep from this hole.
Is yours weeping oil?
Old Aug 12, 2018 | 06:42 PM
2003flstfi's Avatar
2003flstfi
It is working weeping, but only minimal. The split/ crack worries me. Thanks for the info and pics, will keep my eyes on it.
Old Aug 12, 2018 | 07:09 PM
Pitbull_Dallas
If its weeping oil, I'd seriously consider trading it in another bike. That's a very expensive and involved problem to fix.
BobRR
Apr 8, 2019 12:44 PM
Stick_FSMC
Engine Mechanical Topics
Mar 16, 2017 07:56 AM
kino44
EVO
23
Jul 1, 2014 03:20 PM
xrayv65
Aug 20, 2009 03:16 AM
1968FL
Shovelhead
Jun 25, 2009 10:16 AM
