My FXBB sucks
This is my first post! Won't be my last.
I got a 2018 Street Bob. What an amazing bike she is! Before I had a 1992 600 Ninja so I came over to the dark (custom) side.
Sure, I started doing some little things to it right away. One of these things concerns the topic title.
My FXBB sucks air into the tank through a vent. Now, I was sure that she does it through the fuel cap so I ordered a black vented fuel cap. When it arrived it looked great! But I really don't think it's vented. It's a big chunk of machined aluminum. Now, I read all kinds of things about some tanks being vented by a hose and some are not. So my question comes down to this:
Is the tank on the FXBB (FXBR has the same) vented - so that I can use a non-vented cap with zero problems?
I'd like to have some input before I run into problems. Thanks!!
metalmoto
Edit: nevermind jam436. If it's the (awesome) bike in your sig it's not an M8. That or you lost your oil cooler.
Edit: Sorry Now I see you are looking to see if it vents from the cap or another vent.
For example, CA CARB gas tanks have to be vented through a charcoal canister, all others can be vented straight to the atmosphere.... If there was a vented gas cap, it would defeat the CARB requirements ..... I have an '01 non-CA bike with a vent tube terminating to the atmosphere and an '03 CA bike with a vent tube terminating at a charcoal canister. Same vent system, different termination....
On the Twin Cam bikes, the vent nipple is either on the front of the tank (split tanks with a crossover), in which case you can see the rubber vent tube run down the front of the tank, behind the steering head. Other bikes (newer ones, with no crossover hose on the front of the fuel tank) have the vent nipple on the Fuel Pump Assembly Plate that bolts into the top of the tanks, and the rubber vent tube is run down the top of the tank, under the console, to below the seat area....
I have no idea where they put the vent nipples on the tanks for the M8 bikes. A close inspection of the tank for a nipple and a rubber hose leading down towards the engine, should be easy to spot.....
UPDATE: You don't need a vented cap. I got curious and found a 2018 parts finder... your tank has a vent hose as I suspected. Looks like it's on the bottom, right side of the tank. The vent hose is #12 in this diagram...
I have swapped the cap and will ride to work tomorrow with peace of mind. Looks a lot better than the cheap chrome/plastic one
To FXBB owners: it’s a nice replacement fuel cap. Let me know if interested. I paid about €15 including free shipping.
No FXBB.... Not a fan of the M8, won't consider one until the MoCo sorts out the issues...
Currently very happy with my Twin Cam Harleys.... '01 Springer FXSTS, '03 Heritage FLSTCI, and '16 Ultra Classic FLHTCU.... all of which have performance/comfort/ appearance mods...
