Curious Problem for You
Old Jun 26, 2019 | 09:55 AM
Pitbull_Dallas's Avatar
Pitbull_Dallas
Default Curious Problem for You
Was jut out riding and probably rode 40 miles. All was working well. Turned into my neighbor hood and noticed the speedo had dropped to zero (was working seconds earlier), but the bike was running fine. Turned into my street and the bike died. Stopped and tried to restart it and no joy. Turned everything off and then back on and the bike started right up, speedo is working again. Any ideas what problem I'm looking at? Oh, 2007 heritage..
Edit: No codes..
Old Jun 26, 2019 | 10:53 AM
RANGER73's Avatar
RANGER73
Check all your battery connections first
Old Jun 26, 2019 | 11:20 AM
Pitbull_Dallas
I just did that. All connections are clean and tight, including the starter. Right now it starts fine, but I don't want that to happen while I'm on the road to somewhere. Even after it died, it cranked strong, but no start. Only after I turned the ignition off and on did it start and things worked again.
Old Jun 26, 2019 | 11:21 AM
strych9's Avatar
strych9
Sounds like an ECM problem.
Old Jun 26, 2019 | 11:26 AM
RANGER73's Avatar
RANGER73
My next guess
Old Jun 26, 2019 | 11:37 AM
soldierbot's Avatar
soldierbot
A while back, I had a glitchy ignition switch. The bike would run fine and then all of a sudden.... dash lights out and the engine dies. I would giggle the switch a bit and everything was back to normal. Replaced the ignition switch ...problem solved.
Old Jun 26, 2019 | 11:56 AM
Pitbull_Dallas
Yep, I've been there. I had to replace my ignition switch a few years ago for that very reason. That doesn't mean it's not happening again. I don't recall the speedo dropping to zero at that time though. I'll keep a eye on it.
I just took the bike out again for a 10 mile ride and all is good at the moment, but that doesn't mean it will hold. I'll take it for a longer ride in the morning and hope for the best. Beyond the switch, I'd still like input on what might be a cause. Thanks!
GittinThere
Jun 3, 2019 07:41 PM
cuda67bnl
EVO
Jun 11, 2017 01:56 AM
C-130JDriver
EVO
14
Aug 21, 2016 06:29 PM
Garrman
Electrical/Lighting/Alarm
Sep 22, 2015 11:10 PM
grubby
Feb 25, 2009 11:13 PM
