2010 Softail Deluxe (FLSTN) **HEAT**
Old 07-16-2019, 10:47 AM
carburetorjones's Avatar
carburetorjones
carburetorjones is offline
Default 2010 Softail Deluxe (FLSTN) **HEAT**
So I made a thread on here late last year when I had problems with my softail not wanting to start sometimes.
Battery is new, and all my connections seem fine, fluids are fine as well.
This year, when I changed all my fluids I decided to change out the starter relay, thinking that might be it.
Yesterday I went out for a ride. It was 100 degrees in Chicago.
Started right up in the morning, and got to work (19 mile commute) no problem.
Left work at the end of the day and right as I pulled into my garage, it died on me. It was still very hot out, and man I could feel the engine being pretty damn hot.
Tried to start it up and it just would not catch, so I just pushed it into its usual resting place.
Gave it about 5 minutes and turned the ignition to on, fuel pump comes on, check engine light goes away, hit start. Starter turns, still doesn't fire. Engine, still hot.
Went out there this morning, engine is cool, and starts up no problem.
Any of you guys experienced something similar?? What was your fix?
Old 07-16-2019, 03:45 PM
Mike NY's Avatar
Mike NY
Mike NY is offline
I bet Compression Releases would solve the Hot Start issues...Is it a stock motor?
The dying pulling into the garage is a mystery...
Mike
NY
Old 07-16-2019, 04:46 PM
carburetorjones
That's an interesting thought on the compression releases.
I just think it's something broken, a sensor, or something. Because it ran fine for a good chunk of last year.
I did notice that one of the clamps towards the bottom of my frame had come apart.. I'm suspecting I might've hit something after lowering the back end.
But yea, stock motor. Samson true duals with baffles. Everything else is just cosmetic.
So I guess I'll just be riding my backup Sporty instead.
The garage thing was actually funny. It was totally a "Herbie" moment.
Good kid. Got me home first.
Old 08-24-2019, 01:47 PM
carburetorjones
There's been a lot of posts on heat and starting issues on the forum and my solution hasn't been mentioned so I thought I'll post it here.
Crank position sensor and map sensor were replaced this week and the bike has been running a lot better!
calvin candie
03-05-2020 12:25 PM
tvon
04-27-2015 12:26 AM
bikefxds
03-03-2012 08:50 AM
abate1
09-29-2009 05:43 PM
rochkes
04-25-2009 04:25 AM
Quick Reply: 2010 Softail Deluxe (FLSTN) **HEAT**
