Shift Lever Centering Screw
Old Aug 11, 2019 | 04:44 PM
MBofMB's Avatar
MBofMB
Stage IV
Red face Shift Lever Centering Screw
This for a 2007 FLSTF Fatboy 6-Speed. Has anyone been able to figure out how to adjust the Shift Lever Centering Screw HD-35082-07? I have some uneven movement in the trans lever. Bike rear off the ground, 3rd gear and checking forward and rearward motion is unbalanced.
I found info on pre 07 units to adjust the pawl for even movement in both directions but nothing on this "Centering Screw". My problem is "not finding 1st or Neutral. The clutch has been adjusted at the Trans and I have a new cable ordered (broke the adjustor!).
Thanks to anyone that can provide a light on this mystery bolt.
Shift Lever Centering Screw Reference: HD-35082-07 is in the centre – Torx Head Size?
Old Aug 11, 2019 | 05:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The shifter pawl was adjustable on 5 speed transmissions until 1999 on Softails, 2000 on all other big twins.
The adjustment feature went away because of the change in the shift drum, the roller ball detent made the adjustment feature unnecessary, the screw remained, but it was a straight screw, not an adjustment cam.
The OEM 6 speeds don`t have a shift pawl adjustment, the bolt simply centers the shift pawl spring, it`s not an adjuster.
Old Aug 11, 2019 | 06:41 PM
MBofMB's Avatar
MBofMB
Stage IV
Thank you very much for the update ... I was thinking about making a tool to get into the tight spot and loosen/tighten the bolt. You just saved me a big headache. I'll now concentrate on shifter play and clutch adjustments.
Thanks again.
wuneyewilly
Jun 28, 2019 02:37 PM
ThorpeFLH
Apr 3, 2013 08:20 PM
Fathead2003
Sep 12, 2010 02:59 PM
nathanw
Jun 1, 2010 03:54 PM
sdroadglide
Sep 7, 2008 06:05 PM
