Best Oil Dipstick..
Old 09-25-2019, 11:25 AM
Pyro451's Avatar
Pyro451
Pyro451 is offline
Same problem with my '16 FLSTFBS. Dealer replaced the first dipstick under warranty. I get that seal wear out, but that was pretty quick.
Old 09-27-2019, 12:15 PM
hattitude's Avatar
hattitude
hattitude is online now
Received 7,688 Likes on 4,141 Posts
Originally Posted by Flanman55
I did... thanks for the reply the bigger o rings never worked. so i get an new oil dip stick and that never worked either. Bag next I guess
While adding an O-ring to the cap is an old, reliable remedy for a worn/weak cap seal...
If the O-ring or new cap don't work, you MAY have an issue with blow-by... there shouldn't be too much pressure in the oil tank.
If an O-ring and a new cap didn't work for me, I'd first do a compression test. If that was all good, I'd inspect the crank case breather system. Pressure getting by the rings, or not properly vented due to a clogged/broken breather assembly, could allow for too much pressure to build up in the crankcase and find its way to your oil tank....
Old 09-29-2019, 10:09 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 6,029 Likes on 3,074 Posts
I have this issue too with the temp dipstick.
I find that its me not wiping the rubber plug off before reinserting it into the bung. (pun intended)
I just wipe the little bit oil off the tank.
SPRINGER (09-29-2019)
MJHJEA
EVO
59
08-02-2023 12:56 PM
8541hog
06-28-2022 04:42 PM
mballard
Shovelhead
09-13-2012 03:32 PM
WARG
10-16-2007 10:39 AM
BTROUT
02-01-2006 12:12 AM
Quick Reply: Best Oil Dipstick..
