Horn noise while braking with 21" front wheel
Old 09-27-2019, 09:13 AM
LionFX's Avatar
LionFX
LionFX is offline
3rd Gear
Originally Posted by 1004ron
This happened on my rear wheel when I installed new bearings I did not correct seat the bearing on the rotor side of the wheel first (as per the service manual), and as a result the rotor was not perfectly lined up with the calliper.
I would not shim the calliper need to get the bearing on that side correct and depending on the wheel you may need a different set of left and right side wheel/axle spacers.
Your post is really interesting!
The rear wheel does not make any noise, it is perfect so in fact it is strange that there is noise only at the front as I use the same brake pads and discs both front and rear.
How can I check if the bearing is installed correctly? I bought new wheels and they already had the bearings installed. I made two spacers with the lathe lower than 1mm and nothing has changed. How do I determine the length of the spacers according to the noise that I hear while braking?
Many thanks for your help!!
Old 09-27-2019, 05:31 PM
1004ron's Avatar
1004ron
1004ron is offline
When installing new bearing in a wheel, the first bearing to install is the one on the rotor side and it must go all the way home, then place the spacer tube in the wheel hub and the second bearing which should very lightly touch the spacer tube.
For a new different wheel, do a trial fit without the spacers only the axle, then with the rotor dead centre of the slot in the calliper measure the length needed for the spacer on that side - the other side spacer length isn't critical.
Deuuuce
07-20-2016 06:24 PM
EGLSFAN
06-05-2011 01:05 PM
challutz
Wheels/Tires
08-15-2010 08:51 PM
colmeg
10-23-2008 12:05 PM
ron1019
10-24-2007 06:56 AM
Quick Reply: Horn noise while braking with 21" front wheel
