Front end knock
Old Sep 25, 2019 | 02:42 PM
willjob's Avatar
willjob
5th Gear
Default Front end knock
Hi all. Heritage softail 2003 realigned front forks when changing to beach bars hadn’t noticed before with the screen and original bars fitted.since then front end knocks on uneven surface tried heavier oil,no difference changed to progressive heavy duty springs with standard oil just the same,doesn’t seem to be any play in the headstock bearings and everything tight any help would be appreciated some say (they all do that) well it drives me nuts got a thing about knocks sqeaks etc. Many thanks for any help. Cheers from the U.K.
Old Sep 25, 2019 | 03:34 PM
rquest's Avatar
rquest
Try new neck bearings and proper torque adjustment, if these are not withing tolerances they will knock.
Old Sep 25, 2019 | 07:29 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Check the forward tank bolts and make sure they're good and tight.
Old Sep 26, 2019 | 04:32 PM
Uncle G.'s Avatar
Uncle G.
If not these items, check for a loose wheel bearing or worn fork bushings.
Gotham
Oct 20, 2019 11:48 AM
softailJoe
Oct 10, 2011 11:55 AM
PaleRearEnd
Jun 18, 2009 01:00 AM
krub6t9
Jul 10, 2008 09:09 PM
Sillverback
Apr 14, 2007 07:35 PM
