throttle cable rubbing the nacelle
Old Nov 27, 2012 | 06:34 PM
FroggyFatBoy's Avatar
FroggyFatBoy
my 07 FB has the same wear pattern.. such is life.. its a motorcycle, not a liberace piano.
Old Jan 26, 2013 | 06:31 PM
joebad's Avatar
joebad
I have a 2012 Fat Boy Lo. Same problem. I don't play piano anyway.
Old Jan 26, 2013 | 06:44 PM
Cthiebaud's Avatar
Cthiebaud
New to the forum and wanted to start posting so here goes if the rubbing on the nacelle bothers you why not just re-route the cables? or even get a different length if need be (probably not) re routing them is a fairly easy job I re did all my cables and wires in a few hours when I put new bars on. You can really clean it up compared to stock.
Old Jan 26, 2013 | 11:57 PM
txphatboy's Avatar
txphatboy
I believe I am in the minority, but I run my cables behind the bars. I did this mainly to try and make front end look as clean as possible, without running internal throttle, etc. I only run one throttle cable but it is tie wrapped to brake line until the upper triple tree. Clutch cable is routed behind bars also. I have no rubbing or binding, but I did order cables when I installed apes, and I ordered them with this in mind so they would not be too long.
95yj
Exhaust System Topics
Dec 28, 2012 11:19 AM
Sy101
Aug 30, 2012 11:08 AM
Bruce in Montana
EVO
Jun 10, 2010 06:42 PM
big_e78
Sep 13, 2009 02:58 PM
wlbowers
Mar 10, 2007 09:08 PM
