Fender
Old Jan 23, 2021 | 05:58 PM
maverickfe's Avatar
maverickfe
Default Fender
I have a 2000 Fat Boy that I'm putting a 200/55R 17 rear tire on it what size fender should i get for it?
Thanks
Old Jan 23, 2021 | 07:43 PM
stal94gt's Avatar
stal94gt
at least 9 inches wide, but you could purchase a pre-fabricated aftermarket or if there is an OEM look your trying to achieve you can get second hand ones for a good price. additionally 2007 and up fatboys use the same wheel and tire spec your trying to find so look for a used setup if you want it to look factory.
Old Jan 23, 2021 | 10:51 PM
maverickfe's Avatar
maverickfe
Tanks for the reply stal94gt i did buy rims and tires off a later fat boy the rims have the holes all the way around the rims. So i would need left and right supports for the fender off the later year?
Old Jan 24, 2021 | 11:58 AM
bustergut's Avatar
bustergut
The 200 wide tyre started in 2007. The wheels in 2007&8 were moved over to the left in the frame, to match the new 96" engine. I know, cos I had one. (The front wheel looked strange cos it was not centralised between the fork legs...)
Old Jan 24, 2021 | 12:15 PM
maverickfe's Avatar
maverickfe
thanks just trying to make the bike i feel better looking with a bigger tire and staying with the solid rims
Old Jan 24, 2021 | 12:34 PM
bustergut's Avatar
bustergut
Amongst other considerations, the pulleys have to line up, and the drive belt has to clear the rear tyre.
Old Jan 24, 2021 | 12:46 PM
bustergut's Avatar
bustergut
Old Jan 24, 2021 | 02:21 PM
Big Mule's Avatar
Big Mule
The big downside to the 200mm rear tire is you won’t get the mileage out of it. The original skinny rear that you have will last longer.
Old Jan 26, 2021 | 08:10 PM
maverickfe's Avatar
maverickfe
thanks everyone for the help so would i need to change out my swingarm and what other parts and yrs? I tried to get in touch with Bryce05 but nothing yet.
Old Jan 27, 2021 | 03:28 PM
bustergut's Avatar
bustergut
I apologise that this was not entirely accurate, so I should correct and explain:
* In 2007 they kept the same rear swingarm as in 2000 (48746-07), so in 2007 they had to move both the wider rear wheel and the front wheel over to the RIGHT in the frame (there are photos of this on the internet).
* From 2008 to 2017 they corrected this with a new rear swingarm (47573-11).
* Therefore in my opinion if you put the wider rear wheel into your 2000 swingarm, it probably won't line up with the front wheel.
