Wheel centre alignment
Old Feb 12, 2021 | 07:04 PM
Peter Long's Avatar
Peter Long
Stage III
Default Wheel centre alignment
Replaced stock wheel with fat spoke , disc alignment is perfect but wheel is of centre of forks and guard
any suggestions. ??
Old Feb 12, 2021 | 07:38 PM
eighteight's Avatar
eighteight
Who laced the wheel?
As an example the rear on some FLs requires you build in some offset, which proves it can be done on purpose or by mistake
Old Feb 12, 2021 | 07:43 PM
Peter Long's Avatar
Peter Long
Stage III
Bought brand new, straight out of box
its on a fxst if that helps any
Old Feb 13, 2021 | 09:10 AM
JohnnyMagic's Avatar
JohnnyMagic
You will get a lot of 'opinions' on this.
Harley has always had, front and rear wheel "offset from center" on different models.
For BEST (IME) handling and balance. match stock specs.
Have a 2020 Softail with excellent handling and balance.
FRONT WHEEL IS OFFSET FROM CENTER!
Wouldn't change a thing!
JM
Old Feb 13, 2021 | 08:03 PM
back again's Avatar
back again
Put a spacer between the hub and the rotor. Match the axle spacers to the amount of spacer you use. What brand wheel did you buy?
oldbie
Oct 18, 2020 09:43 PM
AngelAir
Wheels/Tires
Aug 8, 2020 04:42 PM
Kevinoffroad4x4
Apr 13, 2015 09:24 PM
slims04
Wheels/Tires
Mar 11, 2011 02:56 PM
