I have an electrical problem and at a loss. I have a 06 springer FXSTS, headlight doesn’t work and 3 of the 4 signal/running lights aren’t working, one of the front has power to the bulb, the rears don’t. But signal lights,horn, tail , dash, and brake lights work.
i’ve checked and replaced fuses, power to fuses, grounds, cleaned connectors, I can get to.
So in one part of your sentence you say the signal lights aren't working, and in the next you say they are. Which is it?
Have you checked the connectors under the dash and under the tank?
