How to put a Softail 2004 (NT) in transport mode???
Old 08-04-2021, 03:00 PM
Rodrigo Santos's Avatar
Rodrigo Santos
Rodrigo Santos is offline
Stage III
Smile How to put a Softail 2004 (NT) in transport mode???
Hi All, I have searched the internet but only found instructions for new HDs with fobs without a button. How do I put my 2004 Night Train in transportation mode? Thank you!
Old 08-04-2021, 03:27 PM
Cobra1's Avatar
Cobra1
Cobra1 is offline
Received 1,289 Likes on 523 Posts
If it’s the fob with the push button I don’t believe there is a transport option. At least the manual doesn’t talk about it. If someone else knows any different, I would be interested also.
Rodrigo Santos (08-04-2021)
Old 08-04-2021, 03:37 PM
Rodrigo Santos
Stage III
Look what I found:
A. If you have an older touring model with a button key fob (that you press to set the alarm)....
1. Turn the main Ignition switch to ON.
2. Press and hold key fob button until confirmation is received (turn signals flash 3 times).
3. Turn the main Ignition switch to OFF.
4. Press and hold key fob button until confirmation is received (turn signals flash 3 times).
5. The motorcycle can now be moved without triggering the alarm.
6. To reset the security system so the alarm sounds if the bike is moved, turn the main Ignition switch back to the IGNITION position.
The following 2 users liked this post by Rodrigo Santos:
Cobra1 (08-06-2021), Travler (08-05-2021)
Old 08-05-2021, 04:28 PM
back again's Avatar
back again
back again is offline
Received 5,053 Likes on 2,210 Posts
Why do you have to have the alarm on when you’re going down the road ?
Old 08-06-2021, 07:42 AM
barneyboy's Avatar
barneyboy
barneyboy is offline
Received 2,643 Likes on 1,540 Posts
When the bike is trailered in transport mode, the ignition/starter remain immobilized, but the motion detector is deactivated. Helps prevent battery drain from the turn signals flashing every time the trailer hits a bump.
Old 08-06-2021, 12:40 PM
ChromeJunkie's Avatar
ChromeJunkie
ChromeJunkie is online now
Received 3,968 Likes on 1,727 Posts
I agree. If it’s an open trailer, just arm the security when parked and away from towing vehicle. That’s what I do when trailering my 06.
back again (08-07-2021)
Old 08-06-2021, 03:29 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,570 Likes on 4,645 Posts
Does the old button fob security system need to be manually armed with a push button on the fob, or does it arm automatically like the newer systems?
Old 08-06-2021, 04:41 PM
barneyboy's Avatar
barneyboy
The older system will auto arm, but it differs from the proximity fob. In other words, it will auto arm (if enabled) upon ignition off, but a button push is required to disarm.
Old 08-06-2021, 05:01 PM
barneyboy's Avatar
barneyboy
Trailering/towing is often painted with a broad brush. Everyone seems to have their preferred methods, whether it be tie downs, ramps, security settings etc. What works for some, doesn't necessarily apply to others. There are situations where transport mode is convenient, set it, and forgot it until arriving at the destination.
Old 08-07-2021, 08:33 AM
hattitude's Avatar
hattitude
hattitude is online now
Received 7,596 Likes on 4,103 Posts
Originally Posted by Rodrigo Santos
Look what I found:
I never knew the older TSSM security systems had a transport mode... Thanks for finding this,... I'll be trying it out later today..
I also never knew the older TSSM security systems could be set to auto arm. I'll have to look that up in one of my older TSSM owner's manuals
I have two bikes with the TSSM security systems and the push button FOBs. I have owned one since 2003. I always thought they were just on/off with the push button FOB. This thread was a learning experience for me... I'll have to save this info.. Thanks to you both
Quick Reply: How to put a Softail 2004 (NT) in transport mode???
