Deuce Starting Problem
Old Nov 9, 2005 | 12:08 PM
Helper's Avatar
Helper
Stage I
Default Deuce Starting Problem
Hello new to the forum. I'm helping out a buddy of mine with his deuce. It will not start. It wont even crank. He said that he could not get it started one day so he jumped it. When I went and looked at it all the turn signals were on even when the ignition switch was off. Hooked up a battery charger to it to get the battery up again and went looking around. Found that when I removed the Security fuse the lights would go out. After reading the manual looks like the security system has gone bonkers. Has anybody had a similar issue. The horn works the brake lights work but none of the turn signals. Thanks for any help
Old Nov 9, 2005 | 08:03 PM
pococj's Avatar
pococj
Default RE: Deuce Starting Problem
You'll need to run the diagnostics and it should give you a code that'll point to the problem. Look down in the DIY Forums.
Deuce103
May 8, 2015 10:00 AM
hoz88
Jun 13, 2011 05:18 PM
jdw2010
Electrical/Lighting/Alarm
Oct 24, 2010 06:33 AM
Obewan36
Apr 4, 2010 03:16 PM
Deucefrog
Nov 2, 2009 10:21 PM
