Overdrive Light issues.
Old Sep 28, 2021 | 11:07 PM
Mike Zdilar's Avatar
Mike Zdilar
4th Gear
Default Overdrive Light issues.
I have a 2012 Harley Custom Deluxe. When I shift into 6th gear and the OD light comes on it sometimes goes off causing the Security light to come on. Before the Security Light comes on the turn signals will not work at all. The Security Light sees there is a issue with the light going out on the OD and there for comes on. This is a intermittent issue. Was wondering if any members have had the same issue and if a fix was found. Was going to loosen the speedo bezel and disconnect the junction plugs and spray contact cleaner thinking there maybe a bad connection. Any Suggestions would be great.
Mike Zdilar
Electrical/Lighting/Alarm
Oct 1, 2021 01:43 PM
jjaym
Feb 24, 2014 08:29 AM
95CHUCK
Jun 26, 2008 01:31 AM
bllx
Sep 1, 2007 07:20 AM
