V&H Exhaust Baffles
V&H Exhaust Baffles
So with the invaluable information provided by Hattitude on my 'Fuel Injection Mystery", there's nothing left to do but install my new Vance & Hines Big Shots. Should arrive here at the end of October. With ordering the Big Shots, I also ordered a set of quite baffles since the research tells me the pipes are real loud. My thought is, I'll try the pipes as they are and add the quiets only if needed.
My question is, since the quiets are fiberglass wrapped and with a plastic film over that, the film is supposedly meant to melt with exhaust heat to fully seal to the pipe, how difficult is it to remove them once they've burned to the pipe, since I may not like the result.
I'd appreciate feedback from anyone with experience on the topic.
Thanks,
Thanks,
It can be a real pain in the ***. I just repacked my baffles on a set of Rush slip ons and the removal wasn’t as easy as just removing the set screw and twisting out🙄. The tape and outer packing was stuck to the walls of the tube. Needed a length of pipe and a small sledge to drive them out then cleaned the inner housing with sandpaper. Applied anti seize on the ends of the baffle before reinstalling.
I've used the quiet baffles in Reaper's V&H Straight Shots, and while they did reduce the volume quite a bit, they also robbed power big time. Before you try the quiet baffles, I would suggest trying a set of DK Customs Thunder Torque Inserts. They lower the volume a bit, greatly improve the exhaust note/tone, and remove the off-idle torque dip that comes with running drag style pipes.
I'm running TTI-158s in the Straight Shots.
Cheers!
Cheers!
DK Custom (12-27-2021)
Good feedback folks. Much appreciated.
There is a YouTube video showing the installation of the quiet baffles and I assume the guy doing the video either read about or just assumed you'd leave the plastic film on it. Not sure this makes unless the idea is to ensure a tight baffle fit without banging around inside.
In any case I won't be putting these in unless the noise is really unbearable. If I do, I'll remove the plastic first.
Thanks to Clammy and 1LargeDog for the feedback.
Clammy (10-29-2021)
Cheers!
Cheers!
Did you install the Thunder Torque Inserts with or without the V&H stock baffles?
Also, was power robbed with the quite baffles at the low, mid or high power range?
Cheers,
Brad
Received 3,963 Likes
V&H quiet baffles rob a bit of the high end power, but still have a dip, or flat spot, in the low end power.
Here is a LINK to a report that you may find useful. Also, feel free to call or email with any questions.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
baffles
The purpose of the plastic wrapped around the fiberglass is so you can slide the baffle in easily. the plastic then melts and the fiberglass expands. The only problem is when you try to get the baffle out it is stuck in there very]y tight and quite difficult to get out
DK Custom (12-29-2021)
