Leaking dip stick
Old Dec 1, 2021 | 03:10 PM
jambo1989's Avatar
jambo1989
Default Leaking dip stick
My 13 heritage oil bag dip stick is leaking. I already bought another dip stick cause you cant just buy the rubber gasket, like $25. Now it's leaking again. Any ideas out there?
Old Dec 1, 2021 | 03:26 PM
brakeless's Avatar
brakeless
Softails are notorious for leaking dipsticks. Are you buying HD OEM dipsticks? The only thing I can suggest at this point is make sure both mating surfaces are clean and dry and push hard. Some don't go fully in and riders don't realize it. Of course there's always a possibility the leak is from increased crankcase pressure due to bad breathers.
Old Dec 1, 2021 | 06:46 PM
Redrodyankneck's Avatar
Redrodyankneck
I agree check the breathers. You should be able to suck air through your breather bolt hoses and not be able to blow air into them. If your crankcase cannot vent properly through your heads then the pressure has to go somewhere,
Old Dec 1, 2021 | 06:50 PM
S.D.M.F's Avatar
S.D.M.F
Over filled oil. Check the level. Sometimes it's the easiest thing.
Old Dec 1, 2021 | 08:24 PM
Tony_N's Avatar
Tony_N
Don't fill it past the bottom of the filler neck.
Old Dec 1, 2021 | 08:27 PM
brakeless's Avatar
brakeless
I don't fill mine past the dipstick full mark which is about 1/2" below the neck. Mine sumps a little sitting so it's easy to make a mistake.
Old Dec 1, 2021 | 08:47 PM
jambo1989's Avatar
jambo1989
Thanks for the replies, I'll check my breathers. And yes the dipstick is a HD oem product.
Old Dec 2, 2021 | 12:55 AM
back again's Avatar
back again
Ace hardware has o rings that work.
Old Dec 2, 2021 | 01:34 AM
Jackie Paper's Avatar
Jackie Paper
Most older models have two radiuses in the seal plug area. Just get two o-rings slightly smaller. Roll one in.
Use the other in a few years. Many on here have been doing that since the first Softail.
Old Dec 2, 2021 | 09:45 AM
brakeless's Avatar
brakeless
Yes the O Rings work but again, make sure you install them onto a dry, clean surface. I've seen them come off and then you have to fish them out of the tank.
