Fatboy basic question
Old Mar 27, 2022 | 08:29 AM
icreepin's Avatar
icreepin
Default Fatboy basic question
I have a 98 EVO Fatboy. I have 0 issues and I just did the full LED conversion. Only down side depending on who you talk to is its carb not fuel injection. Only mods I have done is the carb 6 gallon tank side bags and driving lights screaming eagle exhaust. Everything else is OEM.
When this season is over as I live in Wisconsin I am thinking I want it all blacked out. My plan I am thinking is buy a complete front end replacement new exhaust and everything I can have powder coated black buy new and replace. Then my thought was to have the entire electrical system replaced because it would have been broken down so far it would just be parts not extra labor.
From a financial point would it be better to do that or just buy a all black fuel injected Fatboy?
Old Mar 27, 2022 | 11:08 AM
hattitude's Avatar
hattitude
It is generally cheaper to mod an older bike than to buy a newer bike... but older bikes can develop issues at a faster rate than newer bikes due to age... New bikes have some benefits, the warranty is a big one, but there are others. Currently my newest bike is 2016 (many mods including a 124" crate engine) and I have no intention of replacing it with a new bike...
I also have an '01 with a carb. I really like the CV40 carb... I had one on my '89 Heritage too. It's much better than the butterfly carbs on my old shovel heads....
If you have zero issues, why would you replace the entire electrical system....?? I would inspect it to make sure wires/connections are undamaged, clean and not corroded, but I wouldn't replace anything barring the inspection showing a possible problem...
I have an '03 Heritage (old, but not as old as your bike), that I've had apart numerous times for mods/tweaks. Same with my 2001 Springer. All the electrical wires & connectors are in really good shape... Whenever I remove a connector, I give it a spray with electrical contact cleaner and a small dab of dielectric grease when it goes back together...
Here's a pic of my '03 Heritage when I was "playing" with it a few weeks ago. I did a bunch of work (all by choice, not need) and all electrical connections handled were in very good condition...
Old Mar 27, 2022 | 11:21 AM
F150HD's Avatar
F150HD
why not just buy a bike that fits your needs instead of dissembling a nice EVO someone would appreciate.
My take anyway. I owned a 2005 FB, great bike, with a carb.
Old Mar 28, 2022 | 09:06 AM
eighteight's Avatar
eighteight
[QUOTE=hattitude;20524076]I
If you have zero issues, why would you replace the entire electrical system....?? ./QUOTE]
Old Mar 29, 2022 | 10:22 AM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Your question is one that only you can answer.
You seem to really like your bike, you seem to have had fantastic good results for that bike, you seem to not have much interest in buying a new bike. There ya go.
As for changing it all up to a new dress- that again is only your call. Other than the expense, I don't see any reason to not give the O'l girl a new look if you want. I wouldn't spend that kind of money for just a new look but many do. As others stated - If the electrical harness is in fine shape, I would leave it as untouched as possible. That is where electrical issues stem from -messing with the electrical.
Old Mar 29, 2022 | 12:36 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How on earth do you figure it would only be parts not extra labor?
The idea of replacing an entire electrical system for no reason makes no sense.
Old Mar 30, 2022 | 08:22 AM
icreepin's Avatar
icreepin
Thanks I was just figuring on the electrical because it would be stripped down and if I am gonna ride it another 20+ years why not..
Yeah and just giving a new look actually would be cheaper but was thinking fuel injection vs carb.
Old Mar 30, 2022 | 09:58 AM
MarlinSpike
Don't be scared of carburetors. They have been around a long, long time and millions and millions of miles. They do need to have an owner that understands them and knows how to tune them to be of perfect operation. I have both EFI and carb bikes - I like them all. Don't let that stop you.
Old Mar 30, 2022 | 11:58 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The work you have described does not entail stripping the bike of its electrical system.
The cost of having a shop do this would be crazy expensive.
If you like throwing money away, I say go for it.
Zakk13
Dec 4, 2018 12:39 PM
shuffle
The Dyno Room
Oct 17, 2016 11:55 AM
No Torque
Jul 30, 2016 06:50 AM
WRE4U
Softail Parts
May 27, 2016 06:54 AM
BigPimp
Nov 1, 2013 08:06 AM
