Back fire through carb
Old Jun 3, 2022 | 03:56 PM
Taz77's Avatar
Taz77
Stage III
Default Back fire through carb
New here I have an 05 heritage that not wanting to crank up without a little throttle and would die out at stops without a little throttle. Now it's gone to hiccuping and back firing through the cab an idea's. I've changed the plugs cleaned the breather,and cleaned the IAC.
Old Jun 5, 2022 | 01:00 PM
hattitude's Avatar
hattitude
Did it just start doing this, and was running fine before....??
Any recent work or mods done....??
Have you inspected the tank/petcock screen lately...??
Has it set for a period of time since last start...??
Just based on your description, I'd say check the carb jets for blockage/dirt/debris.... I'd at least pull the bowl with the carb still on the bike and inspect what it looks like in there... spray a little carb cleaner up through the jets...
Good luck with your diagnosis and repair...
Old Jun 5, 2022 | 01:05 PM
IronAss's Avatar
IronAss
Check the plug wires. Make sure they are firmly attached to both the coil and spark plugs.
Old Jun 5, 2022 | 01:06 PM
Taz77's Avatar
Taz77
Stage III
Did it just start doing this, and was running fine before....??just started doing this
Any recent work or mods done....??no mods
Has it set for a period of time since last start...??no sitting
Thanks
Old Jun 5, 2022 | 06:38 PM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
To add to what Mr. Hatitude suggested - Drain the float bowl and see if there is any water in the fuel. Sounds a lot like a restricted pilot jet or water in the fuel.
Old Jun 5, 2022 | 06:41 PM
Taz77's Avatar
Taz77
Stage III
it's injected I guess I forgot to mention that
Old Jun 6, 2022 | 07:15 AM
MarlinSpike
Well, that changes things... I guess I misunderstood the "cab" you stated and thought you miss-printed "Carb". Sorry.
Old Jun 6, 2022 | 08:20 AM
hattitude's Avatar
hattitude
The title of your thread is "Back fire through carb" ....... ??
Old Jun 6, 2022 | 08:51 AM
rigidthumper's Avatar
rigidthumper
Common fuel pressure issue- the hose from the check valve to the regulator developes pin holes, leaking pressure inside the tank. Time to replace the check valve, and the filter, while you're in there.
JRH24
EVO
Oct 23, 2016 12:17 AM
trussham
Carburetor Related
May 1, 2015 05:30 PM
mulch63
Exhaust System Topics
20
Jun 27, 2009 01:39 PM
vetto
Apr 13, 2009 06:12 AM
BADCUDA
Sep 5, 2007 02:32 PM
