fork oil drain plugs can be reused????
Old Jul 22, 2023 | 11:21 AM
Cap77's Avatar
Cap77
Default fork oil drain plugs can be reused????
04 Deuce
Going to grab a qt of 15wt fork oil now
Manual says "one time use" for the drain hole screws.
will the world as we know it end if I reuse the screws and washers?
thanks
.L.T.A.
Old Jul 22, 2023 | 11:33 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If one of them falls out it might...
I don`t second guess the manufacturer, if the book says replace, that is what I do.
Old Jul 22, 2023 | 11:37 AM
Stiggy's Avatar
Stiggy
At $8 or $10 a piece perhaps? Yes the world would end!
I've (obviously,) have always reused fork drain plugs since forever. (Be careful to protect the screwdriver slots, I have used a small hand impact to break them loose cleanly.)
Old Jul 22, 2023 | 11:51 AM
Dan89FLSTC's Avatar
Dan89FLSTC
$4.17 each.
Old Jul 22, 2023 | 11:52 AM
Cap77's Avatar
Cap77
Will the world as we know it end if you buy new ones?.
Nosir, it won't.
But it might put a hitch in my plans if I have to order them
I
I appreciate and respect that, Dan
But I'm not always a "by the book" kind of guy.
I'm still using the same O-ring for the last 4 oil changes
and don't tell my friends, but I've reused the derby cover gasket without mishap too
.LT.A.
Old Jul 22, 2023 | 11:54 AM
pgreer's Avatar
pgreer
I've reused them if they come out cleanly. But I think the James seal kit I used back then had new washers in it. But that's been a good while ago, so my memory may be wrong.
Paul
Old Jul 22, 2023 | 11:57 AM
Cap77's Avatar
Cap77
Thanks Stiggy
I happen to have a small one too.
I use it for gun smithing (in particular removing 1911 grip screw bushings)
..L.T.A.
Old Jul 22, 2023 | 03:33 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Nosir, it won't.
That is why you make sure you have all the stuff you need ahead of time, a 34 year old Softail has taught me that.
Old Jul 22, 2023 | 03:41 PM
M Oclaf's Avatar
M Oclaf
Thanks Stiggy
..L.T.A.
Thats what she said!
TMI too!
Old Jul 22, 2023 | 04:00 PM
Cap77's Avatar
Cap77
she laughed and said,
"who you gonna satisfy with that?!?!?"
I told her, "ME, of course"
..L.T.A.
