Use port
Old Aug 4, 2024 | 08:10 AM
Freebird55's Avatar
Freebird55
Stage III
Default Use port
Hi I知 new here can anyone please guide me to where I can buy the usb port in the uk that fits in the caddy on a 22 softail standard I知 looking for the original part that connects to the two pin connector inside the caddy much appreciated
Old Aug 5, 2024 | 11:01 AM
eighteight's Avatar
eighteight
Check the wiring diagrams at Ronnies Parts Finder
Old Aug 5, 2024 | 11:25 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Are you sure the standard came with the USB port? Looking at the fische, it kinda looks like it didn't.
​​​​​​https://www.harley-davidson.com/us/e...c02e05fac7b8/y
But, if it did, I think it might be part 20 in the drawing, 69202609. That's a big "might", because I can't find a picture of that to be sure, but the price seems to indicate it might be a USB port.
Otherwise, look up some other softail, like a Heritage, that will have the parts 18 & 19 active, and consider ordering them. They should fit, but should and will can be different.
Old Aug 5, 2024 | 01:45 PM
Freebird55's Avatar
Freebird55
Stage III
Default USB port
Hi, thanks for your reply no they don稚 come with the usb data port that痴 why I壇 like to put one on all the wiring and plug is already in the caddy under the tank ready to fit a USB data port but I知 having difficulty finding one I知 told the one fitted to the bobber should fit
Old Aug 5, 2024 | 04:54 PM
foxtrapper's Avatar
foxtrapper
Originally Posted by Freebird55
Hi, thanks for your reply no they don’t come with the usb data port that’s why I’d like to put one on all the wiring and plug is already in the caddy under the tank ready to fit a USB data port but I’m having difficulty finding one I’m told the one fitted to the bobber should fit
OK.
So when you look at that parts listing I linked, it is both specific to your bike, and general to all softails.
All the parts have tag numbers, but only some have a box around them.
Those that are specific to your bike, have a box. Since your bike didn't come with a USB port, the part with tag 18 does not have a box. That is the USB port.
So now go look up a different softail that does come with USB. I used the Heritage, but there are others.
https://www.harley-davidson.com/us/e...00377dfb5c80/y
Now you'll see part 18 has a box around it. That's because the Heritage does come with the USB port.
Click it and it takes you to the part. Part number 69201762, $84.24.
That part does come with the wiring plug on the other end. So you should be able to install it by simply plugging it into the already existing wiring harness in there. Likely capped with a blank plug.
Don't forget to also get the waterproof cap, part 19. Part number 69201764, $9.71.
I think that should be all that's needed to install the factory USB port on your bike.
Old Aug 5, 2024 | 06:55 PM
Freebird55's Avatar
Freebird55
Stage III
Default USB port
Thank you so much for this information that痴 really helpful ✊🏻
Adam76
2018+ Softail Models
26
Mar 29, 2022 03:17 PM
kman78
Jan 22, 2022 10:17 PM
stinkerbill
Motorcycles For Sale
Nov 24, 2016 02:04 AM
loosnut
Aug 25, 2012 09:31 AM
azurevirus
Apr 10, 2007 08:20 PM
