I have a metallurgy question. After lowering my Deluxe, it stands close to vertical. Being the cheapskate that I am I think I'll heat and bend my Jiffy stand. Should I quench in water after bending or will that make it brittle or weak? If I let it air cool will it be soft and bend more easily?
Let it air cool and it will be fine. remember, a dab will do it, don't go crazy with the torch.
I wouldn't trust a stand after heating and bending it. Once you heat it up you lose the original hardening from the initial quench. Gotta ask yourself, what's a cheaper cost? Replacing with a shorter stand or repairing paint, fender, tank, primary, bars, mirror etc if it tips over?
I guess I should have referenced the thread I was thinking of for clarity. Not sure if this qualifies for cross thread points or not. A member asked about drilling a simple hole in the jiffy stand tab to add an extension to make easier to deploy, If my failing memory is correct. It turned into a metallurgical massacre.
Dan
Don't half *** it by heating and bending. Cut off the foot, shorten the shank an inch or so, angle it properly and have a competent welder weld it back on.
