I was wondering if I buy a 2002 SOFTAIL Duece rear solid 17x4.5 wheel will it fit on my 2005 SOFTAIL Duece with out modifications my bike has a 16 wheel on it now and I wanted to go back to the 17x4.5 wheel like the wheel I'm looking at to buy does anyone know if this wheel will fit my bike before i spend the $250 .00 on it
Yes, it will fit. Mr. Paper has posted the correct PN. I am curious about the 16" rear. Are you the original owner? Looks like a previous owner wanted a 16" wheel?
Be sure to double check that spacing Randy, if someone went narrow on that dimension, the spacers will be wrong for that correct wheel. It's also possible the belt is incorrect or the rear drive pulley has been shimmed.
To fit that 17x4.5 in there, Harley used a narrow belt.
The original Dunlop tire had a apx 1/4x1/4 bead molded on tire to give it even a more bolder look.
Things were close under there. Even to the caliper..
The Michelin tire in that size is not as bold as the Dunlop. However, it's a smoother, less harsh running tire. The original Dunlop was also a very fast wearing tire and the front and rear were of a different compound.
I couldn't get 10k out of the rear and I never drove aggressively.
