Adding security system
Old Oct 15, 2007 | 03:47 PM
SGTGunner's Avatar
SGTGunner
Default Adding security system
Unfortunatly my 08 Night Train didnt come with the security system, but I would like to add one on. I got the part number from the cataloge, just got a couple questions about it.
One, where and how does the module mount?
And two, is it 'plug and play' or will the dealer need to program it or work some kind of majic. I'd rather do the install myself if possible.
Thanks yall!
Old Oct 15, 2007 | 04:16 PM
closetredneck's Avatar
closetredneck
Default RE: Adding security system
SGT-
Just went trough this on my 07 train. I had a few probs, but hopefully you can avoid them.
The unit mounts behind the rock gaurd in the "electrical panel". It's easier to jack the bike up so the rear wheel drops. Two bolts, slide the knotch over the clip, and the rock guard comes off. Remove old turn signal module. Plug in new TSSM module, and the siren if you bought it. keep the guard off for now in case you have problems. Put the bike back on the ground on the jiffy stand. Connect battery cable (oh yeah, disconnect before you start).
Now here's where I had my problems. I didn't have the below link. Follow it to a "T".
https://www.hdforums.com/m_120188/tm.htm
Make sure you don't turn on the ignition without following the procedure in the above link and completing it properly. If all works fine, when you're done, bike should start and stay running.
After that, you should be able to just take the bike to the dealer and have them activate the fob to the security sytem.
Old Oct 15, 2007 | 08:56 PM
SGTGunner's Avatar
SGTGunner
Sweet. Thanksa lot.
Old Oct 15, 2007 | 09:23 PM
closetredneck
Just to be clear, the system will not automatically arm until you have the fob activated.
Jimbo33
Apr 7, 2018 08:06 PM
2-Piece
May 10, 2013 11:23 PM
NoRegerts
Jun 27, 2012 10:41 AM
hogster1961
Jan 11, 2012 08:30 AM
softail78
Jun 20, 2010 11:26 PM
