baffles
Old Oct 26, 2007 | 08:16 AM
ghill69's Avatar
ghill69
Default baffles
looking for pros and cons removing baffles from V+H big shots on an 03 fatboy. Thanks.
Old Oct 26, 2007 | 11:39 AM
riles10's Avatar
riles10
Default RE: baffles
might lose some torque due to loss of back pressure running straight pipes...can you pull them out without ruining them? if so, try it and see...sometimes louder pipes comes at a price of losing some performance...little trick I did from reading in here is : I have 2.25 baffles and instead of losing back pressure I inserted a thumb screw into the bafflegetting back some of the pressurewithout losing the loud sound....they call this a lollypop install..in fact I think someplaces sell their baffles with theseinstalled already....Irode my 07 softail without the lollipop and then after thelollipop install it performed much better...jusy my 2 cents....gl
Old Oct 26, 2007 | 01:31 PM
HarleyWood's Avatar
HarleyWood
Default RE: baffles
Which baffles are you running now?
If its the standard baffle I don't think there will be any detectable difference in sound, but you'll likely loose torque. the standard baffle is just a simple ventauri that slows down the exhaust gas enough to make some back pressure.
Old Oct 26, 2007 | 02:13 PM
tn1hot's Avatar
tn1hot
1st Gear
Default RE: baffles
i ride an 07' electra glide classic now, but i used to have an 06' heritage with v&h big shots. some say you can't tell a difference running straight pipesbut i could. you will loose torque and throttle responce. i loved the loudness of the pipes but hated the popping on decel. i ran a big city thunder monster baffle, which is basically a lollie pop set up like some one mentioned and they sound great. deeper and louder . i thought that they even increased my torque and power. check them out at ( bigcitythunder.com )
Old Oct 26, 2007 | 02:19 PM
riles10's Avatar
riles10
Default RE: baffles
bingo to tn1hot !!
Old Oct 26, 2007 | 11:19 PM
serge627's Avatar
serge627
Default RE: baffles
Popping, and very loud without the baffles. My wife had a set of V&H on her 883 without baffles and we put some back in, it was too much. Plus as stated performance losses.
Old Oct 26, 2007 | 11:45 PM
Marsh's Avatar
Marsh
Default RE: baffles
I removed the V&H baffles on my Mikuni 42 carburated 02 Heritage because I didn't like the harsher sound with them in. It's not that much loader without, but the sound is deeper. I put a splitter in the hole for the baffle screw to reclaim lost torque. They don't pop on decel which tells me the carb is set up well for the open pipes. The throttle since the Mikuni install is incredibly responsive
Marsh
Old Oct 27, 2007 | 01:13 AM
moggsy's Avatar
moggsy
Default RE: baffles
Most bikes i have heard without baffles sound crap.Sure they are louder but i would prefer a nice note with bark than just loud.Took my baffles out to see what is what like on my v&h big shots,went around the block,got home and put them back in.
To me its only a temporary measure.Most people will eventually get a set of pipes for there ride.
Old Oct 27, 2007 | 08:20 AM
shortfatboy's Avatar
shortfatboy
Default RE: baffles
sound quality and performance are almost alway better with the baffles...I ran my 2 into 1 without the baffle once, couldn't wait to put it back in
Old Oct 27, 2007 | 08:47 AM
99embrey's Avatar
99embrey
Default RE: baffles
I removed my baffles on my bss, and didn't like the sound. I lost some of the "rumble" as I was accellerating. I reinstalled them, much better. IMO
