Whats the brightest bulb I can get??
RE: Whats the brightest bulb I can get??
I was told by my dealer that if you put an 80/100 bulb in you will run the risk of melting your wiring harness. But, he also said that if you leave the rubber boot off of the back of the headlight when putting it back together that it wont build up as much heat. For whatever that is worth.
