No headlight
Old Jun 15, 2012 | 10:52 AM
Ajackson9687's Avatar
Ajackson9687
Default No headlight
Having an issue with my cousin's bike, the headlight quit working at some point and I can not figure out the issue, I know its never 100% but I did check the resistance through the bulb and it came back as 0 ohms, and the filemant looks perfect so I am assuming its not the bulb, I would go just buy one but the dealer is about 30 minutes away and I don't have the time with my work schedule, the fuse is good, I was never the greatest with electrical but I have traced the wiring down to a white, yellow, and blue wire, the way it looks is that I should have power to the blue wire with the key on but I did not get a steady reading of any sorts and the resistance from the battery to the blue wire at the switch is infinite...anyone want to give me a suggestion on where to go here? what tests I should be doing or what ones I was doing incorrectly?
btw its an 02 nighttrain
Old Jun 15, 2012 | 11:06 AM
NoRegerts's Avatar
NoRegerts
Trace the wire back to the source and ensure there are no loose connections. If you don't find any, use dielectric grease in the connectors.
You've already done the first two steps. Checking the bulb and the fuse.
Old Jun 15, 2012 | 11:21 AM
oct1949's Avatar
oct1949
I went through 3 bulbs in one summer 3 yrs ago..
So I'd get a new bulb anyway just to make sure...
By the way Its Ur Cuz's bike,,, Let HIM go get the new bulb,, Why U worrying bout getting it.
Old Jun 15, 2012 | 12:54 PM
Fatbob usmc EOD's Avatar
Fatbob usmc EOD
Definitely try a new bulb. I had a brake light go out. I looked at the bulb and both filaments appeared intact. Bought a new bulb and it worked fine. I'm also pretty sure that your multimeter shouldn't be reading 0 ohms when testing the bulb. It should show some kind of actual reading, .5 ohms for example or else it would be indicating that the circuit is open. For example in my job if I test a wire reel and the mulitmeter reads 0 ohms then that means I have a break in the wire somewhere.
Old Jun 15, 2012 | 01:08 PM
sagebrush1976's Avatar
sagebrush1976
Its not a special bulb anyways. Just go to your local pepboys/autozone/Napa/checkers etc.. and get a 9003 H4 bulb and give it a try.
Old Jun 15, 2012 | 01:37 PM
CT-Mike's Avatar
CT-Mike
Actually a break in the wire would indicate ∞ ohms. 0 ohms indicates a direct short.
Old Jun 15, 2012 | 07:31 PM
checkers's Avatar
checkers
AJackson, I think that you have a standard halogen H4 bulb on that model. If you are going to buy a bulb to try, go to Wally and buy a Sylvania Clearvision, it is a good upgrade and avail in a single pack.
Old Jun 15, 2012 | 07:43 PM
fat_tony's Avatar
fat_tony
Is the engine running? Most bikes have a relay that will not turn on the headlight till the engine is running to avoid draining the battery.
flhsport
EVO
11
Jul 31, 2016 06:23 PM
langwilliams
EVO
May 13, 2016 08:34 PM
FUQUA
Feb 8, 2010 06:45 PM
jglasgow110
Oct 31, 2007 10:53 AM
phoneguy
May 19, 2006 09:27 PM
