Headlight issue.
Old Feb 7, 2010 | 06:05 PM
FUQUA's Avatar
FUQUA
Default Headlight issue.
My low beam does not burn when switch is on or bike is running, but the high beam is fine....anybody have such issue?
Old Feb 7, 2010 | 06:19 PM
bberck's Avatar
bberck
Time for a new bulb the element for one can burn out before the other. My high beam usually goes out first.
Old Feb 7, 2010 | 06:21 PM
ackman1968's Avatar
ackman1968
Is the bulb good? With the holgen bulbs they some times look fine but won't light. Best thing to do is check for voltage on the yellow wire if I remember correctly.
Old Feb 7, 2010 | 06:24 PM
FUQUA's Avatar
FUQUA
Thanks...i thought it was one in the same by the looks of the bulb. I was starting to freak out because of the ape install.....but i guess if the wiring was wrong it wouldn't work at all.
Old Feb 8, 2010 | 03:41 PM
rounder's Avatar
rounder
If it has ceased to work since the install, then you may have a problem with the low beam wire.... 3 wires to headlight ,low, high, ground. Of course if it did work after install then went out, could just be the low beam portion of the bulb.
Old Feb 8, 2010 | 05:18 PM
07bobber's Avatar
07bobber
Change or check the bulb. Same thing happened to my bike so i ran the high beam until i got home to change it.
Old Feb 8, 2010 | 06:45 PM
FUQUA's Avatar
FUQUA
So i thought it might have been the bulb....i got a new high intensity and installed it tonight,same thing!! Only on high So obviously i did something in the wiring.......****!!! So i guess i start at the lamp and trace backward to the connector?
flhsport
EVO
11
Jul 31, 2016 06:23 PM
Veekness
Sep 29, 2014 07:26 AM
harris48cars
Jul 1, 2010 06:32 AM
deadeye1340?
Feb 28, 2007 07:50 AM
Whiffleboy
Oct 16, 2006 01:06 PM
