Headlight bulb. Blown again
Old Jun 28, 2010 | 11:07 PM
harris48cars's Avatar
harris48cars
Default Headlight bulb. Blown again
I do have 26,000 miles on the bike. But I've blown two headlight bulbs (High Beam). I've never had one blow on any of my other bikes and the mileage on them exceeds what I have now. Anyone have an idea as to way I'm blowing bulbs. Each time it's been the high beam. Anyone want to recommend a different bulb.
Gary
Old Jun 29, 2010 | 12:27 AM
AlaskaAviator's Avatar
AlaskaAviator
You might just be lucky. Try another standard bulb. Make sure the voltage is not to high or low. Should not be below 13 volts with the engine running.
Old Jun 29, 2010 | 07:03 AM
Captain Itch's Avatar
Captain Itch
Sponsor
I have 2 Road Kings and they go thru a headlight bulb about every 10,000 miles.. checked ground wires and the works..Have now gone with Sylvania Silver star model 9003/HB2 ST/2...ADVERTISED AS THE WHITER AND BRIGHTER LIGHT... We will see how they last..
__________________
www.Captain-Itch.com
Old Jun 29, 2010 | 07:33 AM
joe28's Avatar
joe28
Check your voltage when you rev it up, shouldn't be over 15 volts, when in doubt, run another ground, also I have a Royal Enfield that vibrates to beat the band and that beat the heck outta my bulbs.
Buy a better bulb, as the cheaper ones made in China are, well.......
Joe
Old Jun 29, 2010 | 09:57 AM
44492001's Avatar
44492001
I use the HD high output bulb ($23.95) on high beam continuously, and they last 20,000 per bulb.
Old Jun 29, 2010 | 11:06 PM
TennesseeEG's Avatar
TennesseeEG
2009 street glide with two blown high beams in 22K miles. Dealer checked the regulator, said the voltage was okay, and not to ride with high beams (which I do during the day). BS, if the bulb cannot handle running on high beam, I'll find another bulb manufacturer.
Old Jun 29, 2010 | 11:10 PM
AlaskaAviator
The **** that can spew from a dealers mouth never ceases to amaze me.
Old Jun 30, 2010 | 06:09 AM
Mick's Avatar
Mick
Here's a link to some high quality H4 bulbs , the Narva Long Life # 48889 looks interesting.
http://www.narva.candlepowerinc.com/
I personally use the Osram plus 50 70/65 bulb , I don't know how long it will last , but I will use it in the future also , here's a link.
http://www.danielsternlighting.com/p.../products.html
There are differences in the construction of the bulbs , and most manufacturers try to go cheaper if they can , so quality is more important than price to me.
Just a couple options.
Mick
Old Jun 30, 2010 | 07:05 AM
dog155's Avatar
dog155
Try lowering your shift points.Sounds like you might be buzzing the motor.
Old Jul 1, 2010 | 06:23 AM
joe28's Avatar
joe28
One thing that popped into my head...................
You can't touch the glass part of the bulb!
The oils in your hand create a HOT spot and that'll shorten the life of the bulb.
Joe
No one told me life was gonna have THIS many instructions!
