took my lexan off mr metal frame widshield to put on a shorter one... got the bolts out... the old one seems glued on there on something... I do not want to rear the old one up. how in the heck does that sucked come off,so i can bolt up the new shorter one// ?
thanks for advice ... I am stumped .
It is two sided tape. I switch mine back & forth. Try some heat. Get something flat w/o sharp edges (butterknife out of the drawer - **** the OL off)
Once it pops up, they'll come off. If all else fails, go to the Auto parts or paint store and get some 3M trim adhesive remover.
I've never used the new tape they give with a w/shld glass. There is enough residual. Just put my slightly bigger on on last night (the Harley 3" under one)
I have a 4" shorter, slightly narrower one for summer.
Voyager.... I got the same low shield from Memphis Shades that you did. Only in Gradiant Black.
You just need to heat them up a bit and then use a butter knife to get under them and pry them a way. They will come... once you get enough up just use your hands and pull away being careful not to bend them. It may seem like it wants to bend or not come off but it will. I just restuck them back to the new one and put the bolts back in. Fit like a glove.
