'06 Softail Engine Mods ???
Old Jan 3, 2006 | 03:41 PM
Unibomber's Avatar
Unibomber
Default '06 Softail Engine Mods ???
My brother is picking up his '06 Night Train(injected) in two weeks, he was looking at having the 103" kit done before pickup, the dealer is making it sound like its not possible and they arent even sure if he can get the 95" done. Is this all BS brain dead dealer talk, or is HD not fooling with the '06's yet.............I told'em I would ask you boys and someone would know or already have those mods on their '06..........
Old Jan 3, 2006 | 03:58 PM
MegaHDman's Avatar
MegaHDman
Default RE: '06 Softail Engine Mods ???
I wouldnt waste time with the stroker crank or the $2000 plus it will probably cost just to install it. If you want to gain cubic inches, do it by increasing the bore. There are a few high quality 97" all bore kits that will give you very close to the same horsepower and torque without the need for stroking or case boring. Plus they also come with much HIGHER QUALITY cylinder jugs. And give you multiple options for piston compression setup. For much cheaper money.
Stroking a twin cam engine does nothing positive for the engine geometry, increases piston speed(bad) and puts more stress and side loading on the piston rings and skirts(again bad for longevity of the engine), along with more stress on the case bearings. And since he has a new Twin Cam engine the case crank bearing is weak and poor in design already unable to deal with axial(side thrust) loads.
Do your friend a favor, tell him to avoid the dealership, have a quality independent shop with a good reputation to do the work. He will be better off in the long run........
Old Jan 3, 2006 | 04:30 PM
Unibomber's Avatar
Unibomber
Ill pass the info, im sure he will be concerned about warranty issues. But mybe a custom job is the ticket.
Old Jan 3, 2006 | 04:38 PM
MegaHDman's Avatar
MegaHDman
ORIGINAL: Unibomber
Warrenty issue will be the SAME no matter what parts are swapped in or out. HD has to honor the warrenty by law unless then can prove that the aftermarket part installed is the sole cause for another parts failure. Not going to happen with a bolt in 97" cylinder kit. Besides the 97" big bore cylinder kits that are available come with a LIFETIME warrenty on their own cylinders.
People worry too much about the 2 year warrenty, or voiding it.
jackinthebox
Feb 24, 2013 09:23 PM
chopincopper
Sep 22, 2012 07:02 AM
jrfernandez7
Aug 2, 2009 10:54 AM
jimmers1817
May 24, 2009 09:43 PM
HDF Tech
Engine Mechanical Topics
Jun 27, 2005 02:52 PM
