Dry start?
Old Jan 29, 2008 | 05:53 AM
deadman77's Avatar
deadman77
Default Dry start?
Is there a way to build some oil pressure in the engine after it has been sitting for the winter without starting the engine?
I dont want to crank it with the plug wires off as that will just fill the cylinders with fuel.
Remove the plugs and crank?
MikeM
Old Jan 29, 2008 | 06:19 AM
OneBlackFly's Avatar
OneBlackFly
Default RE: Dry start?
See my post www.hdforums.com/m_2759489/tm.htm for which I received few replies. I think this technique might work for us. I've the same concern as you do, dry upper end in the engine.
Old Jan 29, 2008 | 06:46 AM
jeffrey98837's Avatar
jeffrey98837
ORIGINAL: deadman77
MikeM
I don't think removing the crank is necessary.
Old Jan 29, 2008 | 08:08 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
If your parinoid about it you "might" try a small bit of oil in the plug holes to lube the rings and cylinder walls. But overall trying to pre-pressurize the oil system isn't going to do much for you. Unlike normal car engines Harley's make heavy use of ball, roller, and needle bearings instead of babbit bearings. That being the case most parts of the engine can get along fine without the normaloil flow for the few seconds it takes to build pressure.
Old Jan 29, 2008 | 08:30 AM
DeJavu's Avatar
DeJavu
It only takes 2 or 3 kicks on my Evo to have oil pressure. I would assumeby the time an electric start fires up, you already have oil flow and pressure. If you are really anxious about it, pull the plugs and squirt a little oil in. Not necessary IMHO.
Old Jan 29, 2008 | 09:52 AM
DrawDown's Avatar
DrawDown
I really wouldnt worry about it. Like said, after the motor turns over a few times, it has built pressure.
Old Jan 29, 2008 | 02:37 PM
Twolf's Avatar
Twolf
Aw, crap, I posted my reply over here. Sorry. Go check it out...
Old Jan 29, 2008 | 11:46 PM
Twolf's Avatar
Twolf
Guys,
Even if you can't ride, why don't ya fire the beast up every few days and roll it around in the garage or wherever?
I woke up to no work today, SNOW everywhere, but still let her get warm, then rolled her out onto the sidewalk and back a few times...
Old Jan 29, 2008 | 11:50 PM
HFD838's Avatar
HFD838
After years of living in the northeast The best Advice I can give is to do what I did. I MOVED TO TEXAS!!! Where I ride year round...lol like on sunday when it was 70 degrees....Hmmm don't miss Snow at all....LOL GO PATS!!!!
Old Jan 31, 2008 | 05:41 AM
renoa18's Avatar
renoa18
Yeah the few seconds that it takes to build oil pressure is not going to hurt your engine
Ditch'r
Engine Mechanical Topics
May 31, 2017 03:13 PM
Lee Lane
Shovelhead
Jun 17, 2010 08:19 AM
pleasants9
Apr 21, 2010 05:42 PM
67xlch
Jan 17, 2008 10:15 PM
HiTech
Oil Archive (no new posts)
Jan 7, 2006 05:26 AM
