exhaust gaskets
Old Mar 20, 2008 | 02:24 PM
jefnightrain's Avatar
jefnightrain
Default exhaust gaskets
Do you need to replace your exhaust gaskets whenever you remove your pipes or can you reuse the old ones if they look ok & stay in place when the pipes are removed
Old Mar 20, 2008 | 02:26 PM
The Baron's Avatar
The Baron
Default RE: exhaust gaskets
Replace them. They crush when you tighten the flanges down and will leak if you reuse them.
Old Mar 20, 2008 | 04:11 PM
BigMike17's Avatar
BigMike17
I've reused a set I had on with no prblems -
Old Mar 20, 2008 | 04:16 PM
rsavage's Avatar
rsavage
I've been told to replace them. When I changed out my pipes, I asked for the screaming eagle gaskets. The Tech told me that they had had better luck with the regular gaskets when installing V & H duals. I don't know what the difference is as I never saw the SE gaskets and just took his advice on the stock gaskets. For about $10, I wouldn't take the chance on having to do the job over.
Old Mar 20, 2008 | 04:17 PM
The Baron's Avatar
The Baron
Yep, for $10 why take the chance?
Old Mar 20, 2008 | 04:42 PM
Deluxechuck's Avatar
Deluxechuck
I replaced mine when I changed the pipes. They are not that expensive, so I would say do it just because you are going to have the pipes off anyway.
Old Mar 20, 2008 | 04:45 PM
Itsmedant's Avatar
Itsmedant
yea, i've heard the same thing about the SE gaskets....just go ahead and go for the regular gaskets...worked perfectly for me
jude0808
Exhaust System Topics
Apr 13, 2016 06:31 PM
P Diddy
Sep 13, 2012 05:15 PM
RA51
May 4, 2009 10:48 PM
ionate
Aug 29, 2007 10:34 AM
wackyhacky
Apr 7, 2007 07:11 PM
