removing gastank
Old Mar 30, 2008 | 03:21 PM
DaveJ's Avatar
DaveJ
Default RE: removing gastank
ORIGINAL: Mike NY
Cech this thread out. I went witht the standard Harley Braided Crossover but if you plan on pulling your tank alot this might be a good idea.
http://groups.msn.com/harleytechtalk...essage=1192528
Mike
NY
I looked at those a while back, but came to the same conclusion as Citoriplus.
Old Mar 30, 2008 | 05:58 PM
Gadgetech's Avatar
Gadgetech
I don't know if this only works on carbs and it's kinda redneck engineering and I am sure you will question my IQ, but a friend of mine and I do it this way and there is no mess. Take off the two lines that are connected to the fuel flow selector (where you select on off or reserve). One line is larger and comes from the tank, the other has an elbow where it connects and comes from the carb. Stick the elbow piece into a shop vac, turn on the shop vac and the fuel will begin to flow out of the main line coming from the tank. That is the general idea anyway. This gets out about 98% of the fuel.
High Roller
Mar 14, 2015 07:07 PM
olongapo1
Oct 11, 2014 07:52 PM
16VAFXDL
Feb 13, 2011 08:49 AM
kbuckz06
Apr 9, 2010 09:55 AM
DyNaBoB
Apr 8, 2006 12:14 AM
