ST Deluxe Headlight/Passing Lamp Adjust ??
Old 05-06-2008, 03:05 PM
bodhijames's Avatar
bodhijames
bodhijames is offline
Default ST Deluxe Headlight/Passing Lamp Adjust ??
Hi All,I need to get the headlight and passing lamps adjusted on my girlfriend's new 05 Deluxe. We're still waiting for the service manual to come in and my searches have come up without much help. The headlight and passing lamps aren't even close to where they need to be aimed. I pulled the trim ring off expecting to find the horizontal and vertical adjustments, but alas just three screws holding the light in place. It was getting late last night but I did see a large bolt up under the triple tree. Is that what adjusts the light? If so, it looks like that would need to be loosened and then rotate the headlight assembly. If so, any tips on getting in there to do it?Passing lamps....I have no idea so any suggestions would be welcomed.thanks!
Old 05-06-2008, 03:16 PM
Mike NY's Avatar
Mike NY
Mike NY is offline
Default RE: ST Deluxe Headlight/Passing Lamp Adjust ??
The Hedalight sits on a small metal block and is bolted under the Tripple tree like you said. If you loosen that you can adjust side to side. The other bolt goes through the metal block and allows up and down adjustments.
The passing lamps I think just can be moved by grabbing each one and pivoting it. I don't think thereare any bolts to loosen.
Mike
NY
Tomashe
2018+ Softail Models
05-12-2024 07:49 PM
clackavosticus
03-31-2015 07:34 AM
Isle Deluxe
08-23-2010 08:33 PM
Hangfire1
05-30-2009 07:55 PM
Lawdawg
07-08-2006 03:29 AM
Quick Reply: ST Deluxe Headlight/Passing Lamp Adjust ??
