Changing Guage Light
Old May 13, 2008 | 08:09 AM
Rocker SB's Avatar
Rocker SB
6th Gear
Default Changing Guage Light
I'm a new member waiting on my Black Rocker C to come in next week!!! 10 more days and counting!! I will put pictures up after I doa few things to it. Just wondering though...Is it possible to change to backlight on the guage to blue LED's? I've never seen one lit up at night, but I'm assuming it doesn't light up blue...
Looking forward to jumping right in!!
Old May 13, 2008 | 11:07 AM
rockerheadsteve's Avatar
rockerheadsteve
Default RE: Changing Guage Light
Hello Scotty, what took ya so long? Welcome to the forum. No unfortunatly they dont light up blue. Thats a good question about the blue leds. I wish I had the answer for ya
Old May 13, 2008 | 11:25 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
If you can find blue 12V LED's no problem, but it might be easier to just get blue bulbs casue then its just a plug and play thing. With LED's you have to look around for one for the right voltage and socket base on it or if you can'tyou would have to make sure to get one with the right voltage and get thepolarity rightso you canhard wire it into the light circuit. If you put them in backwards they will not light.
Old May 13, 2008 | 12:13 PM
JRK5892's Avatar
JRK5892
agreed, i swaped mine out in my bob for red
Old May 13, 2008 | 12:20 PM
rockerheadsteve
Hey Joe, have ya got a close up of them pipes. Are they Rhineharts?
Old May 13, 2008 | 08:10 PM
m i k e's Avatar
m i k e
ORIGINAL: Rocker SB
you can get blue lite blue or any other 600
colors for 499.99 dual tach/speedo kit
looks ok as well its on 1 of these post
Old May 15, 2008 | 06:51 PM
bdejong11129's Avatar
bdejong11129
It isnt necessary to get an led that runs exactally at 12 volts, most Blue LED's run at about 3.3 to as high as 4.2 volts. You have a few choics, you can use a few of them in SERIES, say three of them which will take on average 10.5 volts and then use a resistor to take up the remaining 1.5 volts. You will need to use a resistor no matter how many LEDS you cram in there, this is to limit the amount of current the LED will draw. This is also how you can control the brightness.
I work for a company that makes LEDs and they are very simple to use. So if anyone is really interested I can explaine in better detail how to get it all to work.
Old May 15, 2008 | 08:04 PM
bdejong11129
Just took a close look at my console and while I can change any of the other indicator LED's, the Spedo is a sealed unit and other than cutting all the plastic around the mounting tabs to find where the indicator light is there doesnt appear to be a way to change it.
I did find a way to dim down the high beam light though...man is that thing bright.
wc00000001
May 27, 2018 09:54 AM
pettit1219
Feb 4, 2016 10:39 AM
Striker951
Dec 13, 2010 10:02 PM
Grrrl
Mar 5, 2010 12:04 PM
