Springer ape riser bushings
Old 05-17-2008, 09:35 AM
roofer's Avatar
roofer
roofer is offline
Default Springer ape riser bushings
I am installing my gooden tite riser bushings on my springer and have a question the manual says to torque the rigid fork leg stud to 65 #s do you use any locktite and the lock nut to 25#s which is a bolt using the good n tite bushings so any locktite on that one. Thanks and also I noticed that the grounding spring is gone do I need that if I am relocating the signals to the forks. Thanks again[align=right]
[/align]
scottysalesman
11-19-2017 03:31 PM
fester1
04-26-2010 01:55 PM
livingitup
05-21-2008 11:30 AM
wac500
09-14-2005 10:50 PM
SPRINGER
02-25-2005 10:25 AM
Quick Reply: Springer ape riser bushings
