Basic Seat Question
Old May 20, 2008 | 05:18 AM
harley_nova's Avatar
harley_nova
Default Basic Seat Question
What is the simplest way to take off the stock custom seat? I have loosened it from the back, but can't seem to figure out a easy way to remove it from the grab handle. Any ideas and suggestions would be much appreciated
Thx
Old May 20, 2008 | 06:33 AM
PCW's Avatar
PCW
Default RE: Basic Seat Question
Me too. The manual you get stinks. It's like the answer to everything is "See your stealership."
Old May 20, 2008 | 06:45 AM
harley_nova
Yeah I know. I sure as hell am not driving an hour to the stealers to ask 'How do I remove my seat?' 1. I would fell dumb and 2. it shouldn't be that difficult!!
Old May 20, 2008 | 06:58 AM
jb55's Avatar
jb55
Hey guys, I took mine off last year. I don't remember anything trick about it. I'm pretty sure the grab strap has to come off with it as well. I will go out to the shed after work and look at the stock seat to see how it came off. If nobady else replies I'll try to give you a better answer tonite.
JB
Old May 20, 2008 | 07:12 AM
harley_nova
Hey, Thanks jb55. There is only one bolt holding it on, but it seems next to impossible to get in there and take it off with only two arms and then trying to put it back it would be painful. Curious to see how you do it
Old May 20, 2008 | 08:21 AM
billtx's Avatar
billtx
Swivel the seat a little sideways once it's loose front and back. Then grab the front of the seat and pull the seat through the strap. Least that's how I did it..
Old May 20, 2008 | 08:22 AM
SoftailC's Avatar
SoftailC
I have had mine off a couple times, remove the two acorn nuts from the back and pull it forward to dislodge the studs from the sissy bar and then push back on the seat to dislodge the tongue from the frame and then swing it either direction and slide it out of the grab strap. I watched the stealership do it a couple of times.
Old May 20, 2008 | 08:33 AM
harley_nova
Great. Thanks guys. No how about putting it back on? That looks to be the difficult part.
Old May 20, 2008 | 08:34 PM
tnharley7's Avatar
tnharley7
SoftailC is correct on removing the seat. What you guys are missing is that you have to flex the seat to get it out of the tongue in front and to re-insert it into the tongue and flex to position it back into the sissybar. It won't break. Don't be afraid of it. It really is easy to do.
Old May 20, 2008 | 08:50 PM
*NIGHT TRAIN*'s Avatar
*NIGHT TRAIN*
ORIGINAL: tnharley7
Some seats are a little different from others, but +1 on the don't be afraid to work it, they're not fragile...
