dyno tune w sert and elevation question
Old May 25, 2008 | 10:48 AM
keno's Avatar
keno
Default dyno tune w sert and elevation question
I live in southeast Arizona and elevation is 4632 feet. My son lives in Colorado and elevation is 5546 feet. He has a harley mechanic that does dyno's a lot cheaper than I can get it done here. Will the difference between elevations (914 feet) screw me up or is it okay to go ahead and do it there?
Old May 25, 2008 | 12:54 PM
XARAN's Avatar
XARAN
Default RE: dyno tune w sert and elevation question
I dont think a thousand feet will make any noticeable difference.
My dealer that did my dyno tuneis at sea level in the Marina and I live in the SB mountians about 60 miles away and at anelevation of 3500 ft. My bike runs great riding at the beach or at home in the mountains. I commute to work from home (3500 ft) to almost sea level a couple of times a week.
Old May 25, 2008 | 03:58 PM
keno's Avatar
keno
Thanks man
Old May 25, 2008 | 04:18 PM
Archer1968's Avatar
Archer1968
Someone will correct me if im wrong but only carb engines get affected by altitude, fuel injected are either close loop or open loop systems and they give and take for altitude....
Old May 25, 2008 | 05:33 PM
tk353's Avatar
tk353
The carb and the efi are effected because it is the air density that changes the afr. If the bike is in closed loop then no it is not effected because the thinner air will make the bike rich and the closed loop will compensate.
Old May 25, 2008 | 06:23 PM
keno's Avatar
keno
So is mine a closed loop? I have no clue..
Old May 26, 2008 | 06:15 AM
screamn_eagle's Avatar
screamn_eagle
it doesn't really matter, your not going to a much different altitude. i took a trip with the wife a few years ago...we traveled all through colorado...up through independance pass and through the valleys. we finished the trip in vegas...i was as high as 12000 feet and as low as sea level. the efi adjusted for each leg of the trip, it was seemless, until we hit the traffic in vegas. 103 SE engine and 5 MPH, in 120 degrees, she started to sputter, but i dont think altitude had anything to do with it.lol..
Old May 26, 2008 | 08:59 AM
flibuoy's Avatar
flibuoy
The injection does make a bit of a difference in how it runs at various altitudes. HOWEVER, relax because most folks don't realize it but density altitude at a given altitude varies with temperature, barometric pressure and humidity. For instance: if you live/ride at 1000' the density altitude can easily vary 2000' either wayon a daily basis and I would venture to say even your carbed bike generally never lets you know...
I took the cog railway up Pike's peak (about 14,000') and talked with several ridersat the top on all sorts of bikes and none had a bad running engine, just down on power due to altitude. Frankly I was surprised. Carbed piston powered airplanes have a meansto adjust steady state mixture, even injected engines, which run smoothly enough have a means to adjust fuel flow for adjusting exhaust gas temperature to a point of best economy withoutgetting too hot.
Blah blah blah....I just realized I was trying to sound like I knew what I was talking about...get it dynoed and it will be fine
rogros
Mar 29, 2008 08:05 PM
Jdartfordct
Dec 27, 2007 05:13 PM
Gjerb
23
Jul 23, 2007 07:10 AM
Icepickvic
Jun 8, 2006 08:28 PM
sws1
May 10, 2006 09:48 PM
