clutch lever
Old Feb 27, 2006 | 10:51 AM
joechief's Avatar
joechief
Default clutch lever
Hey, I'm new to the forum, just bought my first Harley, its an '87 Heritage. I haven't had a bike for about 20 years. Quick question, the clutch lever on this thing is really hard. The cable may just need lubed, if so what do you guys recommend, or will is an adjustment needed? The clutch works fine.
Thanks
Old Feb 27, 2006 | 11:14 AM
HDF Tech's Avatar
HDF Tech
Default RE: clutch lever
Best I have found... http://www.ironbraid.com/driside.html
Some other usefull info... https://www.hdforums.com/m_67591/tm.htm
Clutch adjustment the easy way.. https://www.hdforums.com/m_70839/tm.htm
Take a look here too... https://www.hdforums.com/forumid_241/tt.htm
Welcome to the forum.
Old Feb 27, 2006 | 05:55 PM
beastmaster's Avatar
beastmaster
motion pro cable lube should help you out
Old Feb 27, 2006 | 09:05 PM
BBDeluxe's Avatar
BBDeluxe
Also......
the new '06 softail models have a light clutch pull, due to different ramps. My dealer says that they can modify the ramps in the old Harley models' clutch handle and make them pretty light....or at least a lot lighter. You may want to wander by your dealer and have the techs do the work to your clutch. But do make sure your cables are OK and well lubed, too. Nothing worse than having a clutch cable go on you while riding.
Bones
Reino's Avatar
Reino
Lube the cables Joe, should help a bit. The EVOs did have a heavy clutch, I used to use it as part of my gym workout .
Old Feb 27, 2006 | 10:28 PM
LRonHoover's Avatar
LRonHoover
Tell your parts guy you want an EZ CLUTCH!. You have to remove the right side tranny cover to install it, but you'll be amazed at the results... should set you back about 25 bucks.
Old Feb 28, 2006 | 12:43 PM
joechief's Avatar
joechief
Thanks all, I will give these things a try. The good news is my hand is getting stronger, with a very powerful grip, just like when I was young!
Thanks
Old Feb 28, 2006 | 01:42 PM
fxstcguy98's Avatar
fxstcguy98
I have a 98 evo and the clutch pulls just as easy as the front brake. I have ridden friends bikes that were evo's and tc88's, some were hard to pull, others weren't. Lube the cable, if it stills pulls hard, take the lever off, clean out the pivot hole and plastic bushing, lube it and put it back together.
Old Feb 28, 2006 | 08:25 PM
Reino's Avatar
Reino
ORIGINAL: joechief
Thanks
keep this clean Joe
btw, happy birthday.
Old Dec 15, 2010 | 10:33 PM
Papi's Avatar
Papi
What do you use to lube the lever pivot pins and the levers
themselves?
