passing lamp
Old Jun 18, 2008 | 01:03 PM
flyburch's Avatar
flyburch
Default passing lamp
trying to change bulb in passing lamp on my fatboy cant get the new one back on correctly&nbsp\\; .. i cant get the trim ring to fit back in the groove.&nbsp\\; is there a secret
Old Jun 18, 2008 | 01:35 PM
NC Pirate's Avatar
NC Pirate
Default RE: passing lamp
No secret, you just have to pull it out on the sides until it slips over the edge.&nbsp\\; I have to take the screw and nut at the bottom all the way&nbsp\\; out......
Old Jun 18, 2008 | 02:26 PM
flyburch's Avatar
flyburch
yea i did that but there is a ring that goes behind the lamp that seems to be keeping it from going over that lip i pushed hard and still wouldnt go on just dont want to bend something
Old Jun 18, 2008 | 04:18 PM
eagle1eye's Avatar
eagle1eye
Maybe your wires are binding it up. You really have to get a good gap to get it over the ring. Did you purchase the whole bulb assembly or just the lamp. I checked the prices of the new light &amp\\; it was pricey. I carefully removed the rubber boot &amp\\; took the lamp apart. Bought new 55w lamps at advance auto for $4.99 each. They're much brighter &amp\\; the fix was way cheap.
Old Jun 18, 2008 | 04:23 PM
flyburch's Avatar
flyburch
got whole bulb assembly no wires are in the way i think im just doing something wrong.
Old Jun 18, 2008 | 07:10 PM
Joe Diver's Avatar
Joe Diver
I just put visors on mine and had to replace the stock clamp. There's a ring behind the bulb that has slots in it so it only fits one way. Make sure everything is lined up properly and the bulb housing seated. Snap in the top of the clamp, then press it and work it around to the bottom. The passing lamps were easy but the headlight I had to work at.
2002flstc
Jan 1, 2017 03:11 PM
zyban
Mar 10, 2016 03:27 AM
canicta
Apr 26, 2013 06:50 AM
Snowfly
Aug 29, 2011 06:23 PM
Badbagger
Touring Parts
May 27, 2010 12:27 AM
