1999 fatboy no speedo or odometer
Old 06-28-2008, 10:23 PM
fatboyjohnny's Avatar
fatboyjohnny
fatboyjohnny is offline
Stage I
Default 1999 fatboy no speedo or odometer
allright guys, new to the site and new Harley owner, just bought a used 1999 fatboy couple weeks ago and love it.&nbsp\\; Couple of days ago speedo starts acting crazy, just works at idle , odometer also.&nbsp\\; Changed speedo sensor and still a no go. any more ideas or tips??, Ill look through the rest of the sight while Im waiting Ive seen this issue on here and got the speedo sensor and location so maybe there will be more help!!&gt\\;&gt\\;&gt\\;
Old 02-20-2011, 11:16 AM
wlvrne's Avatar
wlvrne
wlvrne is offline
2nd Gear
I have the same problem on my 98 Fatboy. Did you ever figure out what was wrong?
Old 02-22-2011, 09:46 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
V-Twins & Bowties is offline
Odds are the speedo itself is shot. Electronics ............ works or it doesn't.
Old 02-22-2011, 03:49 PM
dub976's Avatar
dub976
dub976 is offline
how charged is the battery? I've had that happen on 2 kawis I've had in the past. it ended up being a bad battery. at idle it was fine but otherwise it would just jump around the whole time. just another thing to look at.
Old 02-23-2011, 08:12 AM
wlvrne's Avatar
wlvrne
wlvrne is offline
2nd Gear
Battery is on a tender fully charged. I took the dash off and took it in the house to check it out and let it warm up. Put it back on the next day and the odometer works. I assume the speedo does also but with the snow and it being about 19 degrees outside here in CT I have not tested it yet.
Old 02-23-2011, 08:24 AM
V-Twins & Bowties
If it works intermitantly and connections are good, I still say the speedo is no good.
Old 02-24-2011, 08:25 AM
wlvrne's Avatar
wlvrne
wlvrne is offline
2nd Gear
I think you may be right. It seems to be a temperature issue though.
Old 02-24-2011, 10:25 AM
V-Twins & Bowties
Makes no difference, unless your just going to ride on the days it works.
r12b1299
EVO
04-01-2019 08:00 AM
mtnman0618
05-05-2015 10:53 AM
silly millie
08-02-2014 10:08 PM
happyhrs
Electrical/Lighting/Alarm
03-13-2014 07:51 AM
MickW
07-03-2006 01:05 PM
Quick Reply: 1999 fatboy no speedo or odometer
