 \\;Anyone have a fix to \\;a leak/weeping banjo bolt that holds an SE air cleaner on? \\;Only the \\;rear one leaks at the washers. \\;
On the back side of the mounting plate should be 2 o rings, 1 for each side. Make sure these are there and may not have been replaced with kits but reused the stock ones.
Regardless of the kit, those two banjo bolts attach to the same place and they require o-rings that should have been there with the stock filter. If not there it will leak.
