Hi guys , I have popping sounds on my V&H exhaust when I ease of the throttle is this happening because it is running rich a bit ? My bike is a HD NT 08 with big sucker , V&H SLS and the Dobeck TFI installed set on stage one . bike has only done 120 miles .. any ideas please.
I bought mine because it was the simplest and most cost efficient way to solve my need. And it has nothing to do with "mapping", you set it using your tach and a small screwdriver.
http://www.techlusion.com/[/align] \\;\\\\\\;[/align]Chris also said I could call him on settin up the Gen III unit[/align] \\;\\\\\\;[/align]To contact us in person or via USPS our address is:
To contact us via phone please call us at:
(877) 764-3337
(406) 388-2377
(406) 388-2455 FAX
you need to adjust mode 4 to make the poppin quit when you let off on the throttle. Adjust the red for more fuel when running.[/align] \\;\\\\\\;[/align]Look for the 1640 St instructions for the Big Shot.[/align] \\;\\\\\\;[/align]Doebeck performance used to own Power Commander by the way.[/align] \\;\\\\\\;[/align]
http://www.techlusion.com/[/align] \\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\;[/align]Chris also said I could call him on settin up the Gen III unit[/align] \\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\;[/align]To contact us in person or via USPS our address is:
(877) 764-3337
(406) 388-2377
(406) 388-2455 FAX
you need to adjust mode 4 to make the poppin quit when you let off on the throttle. Adjust the red for more fuel when running.[/align] \\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\;[/align]Look for the 1640 St instructions for the Big Shot.[/align] \\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\;[/align]Doebeck performance used to own Power Commander by the way.[/align] \\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\;[/align]
Close, but not exactly correct. \\;\\\\\\; Mark Dobeck worked for Dynojet, then struck out on his own forming Techlusion. \\;\\\\\\; He developed the TFI/DFO as an alternative to the more expensive, more complicated PC for those of us who just need to "rejet" our EFI.
I run the Dobeck and I've had mine dyno'ed. The air/fuel mixture is almost perfect and I still get some popping on decel. It's popping on acceleration that you need to worry about.
